Hi, I appreciate all who are reading this and offering their assistance. I have an Aqua Rite T-9 cell, about 6 years old so maybe near the end of its life. The main board is much older. My display board has been a bit wonky for a while so here is what is happening.
Recently, the generating light comes on solid upon startup and then about 30 seconds later the inspect cell and check salt light flash. The generating light would stay on. this happened for a few days
Now, the generating light comes on and the inspect cell and salt light stay on and the generating light goes off. The power light is also on.
I replaced the thermistor and no luck. Actually, shortly after replacing it is when the lights went from flashing to staying on.
I tested the cell using the 5 gallon bucket test and I am seeing a lot of bubbles and chlorine, so seems like the cell is good. see attached picture.
One odd thing, when I turn the pump on the salt panel does not come on. I have to take the display board off and then reseat it back and then the salt power comes on. This seems to be routine now as it has happened several times in a row.
here are my readings. It is reading very low salt but I believe it is much higher. I am going to have it tested again today but last week it was 2500 and I have since put in two bags. Not sure if the low salt is why the lights stay on but I thought they would flash. I understand I need to get a correct reading of the salt before maybe being able to determine what is going on but no power upon startup seems to be something else.
2200
81
32.4
0
70
0
al 0
15.5
t9
Does it seem like maybe a bad board and display? As I was messing with it yesterday I did accidentally change it to a T15 which I read would cause this probably but I changed it back and The T9 reading is what matches my cell.
Thank you
2200
81
32.4
0
70
0
al 0
15.5
t9
Thank you
