The display is stuck on 170, it boots up showing 170 and never changes - pressing salinity/temp buttons does nothing. I disconnected the temp sensor and it still shows 170. Can't run front board tests because display is always showing 170.
This problem just started after our fence was pressure-washed prior to staining. My current theory is that water was blasted into the sides of the AquaPure1400 housing (cracked around the 4 screws) causing something to short on the front board. Close visual inspection of the front board didn't uncover any burned components.
Any other theories for a stuck 170 display?
