I have been researching and calling pool supply dealers and Hayward tech support for two days trying to figure out how to replace my pool pump and getting no where
I have a single speed two horsepower pentair pump model 340040 that is making grinding noises and I assume is about to fail. I think it's original with the house and 12 years old. I'd like to replace it with a two speed or variable speed pump.
i have the goldline aqua logic controls, the remote says model aql-ttb-rf-ps-8. On the inside door panel of the aqualogic it says aql-ps-8 . On the actual front of the unit there are numbers that's say 956001a(l) and 954001a
If I scroll through the diagnostic screen on the remote it says:
Main Software
Revsision 2.86
Display Software
RFRem=08 r2.00 S:32
RF Base software
r1.20 ID: 155B
i have a hot tub higher than my pool which spills over into the pool in spillover mode. I have a Lars heater. I have a seperate booster pump for Polaris buts it grabs the water from the same pipes as the main pump. I have a seperate pentair pump which runs a waterfall
First I called pentair and they thought model 340044 would replace mine as a two speed and maybe 342001 1.5 hp as a variable speed. It has less hp but he said the rpms looked the same. They didn't know if my aqualogic could control either
Waited for over hr half to talk to Hayward pump tech, they had no idea and told me to call goldline specifically. Talked to the automation tech and they said I'd have to talk to a dealer bc they no longer give support on programming or compatibility or could look online.
Talked to a couple local dealers, two suppose to call me back yesterday never heard. One was helpful and had somebody from Hayward call me. He wasn't sure on aqualogic but thought I could consider upgrading to the Omni vs which could control four features but is pretty pricey, close to $2k or re doing the whole thing Omni. He checked with another tech guy and told me this morning that no vs would work with my aqualogic.
I was iñterested in the sp3202vsp which is 1.85 but he thought would work with my pool bc the old pentair they said is more like a 1.5 hp motor output wise.
But it if I can't control it with my aqualogic it would be a pain switching to spa and freeze protection etc.
My configuration menu gives me the option to pick a variable speed pump so I'm not sure why no variable speed pump will work with it
Can anyone help or give me advice ? Thx!!!!
Main Software
Revsision 2.86
Display Software
RFRem=08 r2.00 S:32
RF Base software
r1.20 ID: 155B
