Purchased a home with a Aqualink RS and iAqualink 2.0 set-up. The iAqualink 2 has no lights on it when the Aqualink RS is powered on. I opened the Aqualink RS and it looks correctly plugged into the correct port. Is the iAqualink likely dead?
Thanks for your suggestions. It does look like from the multimeter readings that it is giving power from the Aqualink RS to the iAqualink 2.0 cable (22.5V). I removed the red cable on the far left and reseated it, but the lights to the iAqualink 2.0 still don't turn on.Welcome to TFP.
Check the voltage between the red and green wires at the red terminal bar (terminals 1 and 4). If the voltage is between 8 and 10 VDC, check the polarity. The red wire is positive (+) and the green wire is negative (-).
If you have voltage at the antenna then some LED should be lit.
Post pictures of the PCB and antenna board connections.
Jandy Troubleshooting Manual for AquaLink® RSAll Button and OneTouch™ Control Systems covers many common problems.
Thank youIf you have good voltage at one end and not the other end, it is probably a bad wire.
Open up this tangled red wire to see if it is ok.
You can replace the wire to see if that helps.
Not yet. Haven’t been able to try yet.Did you get it fixed?
