- Jan 7, 2012
- 1,511
- Plaster
- Pentair Intellichlor IC-60
Just got a new AquaCal SQ150VS and everything works fine in stand-alone configuration. However, when I attempted to control the heat pump with automation (IntelliCenter), when the compressor started up, the IntelliFlo pump shut down. The IntelliFlo started again by itself around 30 seconds later, and then the process repeats itself endlessly. As far as I can tell, the control cable is connected correctly and things are setup correctly in IntelliCenter. Any ideas?
