Shut off power to everything and disconnect the wires going to the transformer from the circuit board.
Insert the test probes and measure resistance between the Blue & White wires and then the Violet & Gray wires.
The readings should be 2.0 - 2.9 Ohms.
If the readings of either of the two measurements are not 2.0 – 2.9 Ohms, the transformer is faulty and should be replaced (GLX-XFMR).
Here is a document that describes additional tests. At the end is a description of how to read the serial number of the box for the date code. The serial number is on the inside of the door.
Is the error "Comm Error 1" or "Comm Error 2"?
‘Comm Error 1’ is usually a false error caused by an abrupt power outage.
‘Comm Error 2’ is usually a misplaced wire in the sensor terminal block, a failing wired remote, a failing local display or a failing main circuit board.
Check the wire going from the local display to the circuit board to make sure that it's connected securely.
Do you have a remote for the system or do you do everything at the box?
