Yeah thanks James, I guess it could be the transformer or the board, but I’d also suspect it’s a heat issue that caused this problem somehow. The panel gets direct sun from around 2-5pm. I checked at 6pm yesterday, noticed a few things:
- the humming sound (and hot)was present even though the pump and swg stopped at 5:30pm. Noise stopped when I pressed on the transformer slightly, and resumed when released. Something in there must be vibrating, not sure which part. Screws are tight. Weird thing is, if I reboot the aqua logic, the humming goes away. Could a board circuit go haywire when hot and stay that way until reboot?
-I tried to turn on the pump but it gave me “check system” light and “pool comm error”. On the pump was some “poor comm signal connection” message. First time i’ve seen these, not sure why this error. Rebooted the aqualogic, no go. Rebooted the ecostar pump and everything back to normal, no more humming.
today will be ~8 degree higher (84F), I am taking out the inside cover in hope the board/transformer would have more room to release the heat. Will see how this will go in the PM.
