All,
I was wondering if anyone had experienced this issue with the Aqua Lamp system. When I was opening the pool and I was brushing down the sides I snapped off one of the mounting pins from the ring that is attached to the wall.
Here is a photo of one of the rings with the pins attached, (circled)
Do you know if I need to drain the pool below the light before I replace this ring or will the water pressure be enough to hold the liner against the wall
Thank You
Ian
Thank You
Ian
