Hello. Glad I found this site and value all the info people are sharing.
This is the first pool I'm building but had a pool at a previous home for a couple years. I have talked with 4 builders in the Phoenix area here's the latest plan we are considering. I had installed a Pentair VS pump and salt cell at my old house and really liked it but 3 out the 4 builders I'm talking to are using Hayward. The pb who gave the bid below said that Hayward is more efficient and the Paramount infloor cleaning has lifetime warranty so I'm considering being open to switching. He also recommended just starting with chlorine and if I don't like it add the salt cell later. I was ok with this because then I could get whatever I want.
The dogs are probably going to be using the pool the most so wanted a large shelf and bench to stand on. I had wanted the first step to go all the way across the pool but the pb advised against it. We thought about having a gas heater and spa but at about $25K for the quotes we received I don't think we would use enough to get the value. Would getting an electric heat pump add many more swimming days in AZ?
Appreciate any suggestions on this build or recommendations in the Phx area.
Thanks!
Thanks!
