App doesn't listen to me
WHen I go to enter my new test results that is when I have the option of choosing F or C. Look at that button next to where you add your value- change it.
I just test drove that and it held the change in my logs and when I next went to add new results.
Reactions: PeterPasieka
I just reproduced the problem. I usually log temperatures in C (Australia). After I read your post, I added a new log with a temperature in F, which worked. Then I added another log with a temperature in C, but PoolMath saved it in F, as you described.
Deleting those dummy logs didn't help, restarting the app didn't help.
What did help in the end, was entering a temperature in C via CSI on the Home screen. After that, I was able to log temperatures in C again.
Try that. If you can't see CSI on the Home screen, then activate "Track CSI" in the settings.
