I have an Apera PC60-Z and my temp readings were way off on the unit, stuck at 110-120F, no idea how long it had been like this as I hadn't really looked at the temp on the unit much since I have another digital temp for the pool on the heater. It looks like the batteries leaked some acid, the springs at the bottom had some fluid on them and there was some gunk on the outside bottom of the battery case inside the unit where the green wire connects the board to the battery case. I used some lemon juice and electrics cleaner to clean the gunk all out as it was really easy to disassemble. Also cleaned where the prob end connects with the pins to the main body. The temperature has now become much closer to what it should be ~74F vs actual 68F.
I have a new probe on the way as Apera said the probe was probably bad since it and the main unit was bought in 2021 when I spoke to them. This was before I noticed the battery leak, so there may be nothing wrong with my probe. Anyone had any experience with this before? I'd prefer not to buy a brand new unit if I don't have to.
Something else I noticed was that the two conductivity tips of the prob are not solid black they have quite a bit of white on them (pic attached). Could this be causing any of the issues with the temp? Anyone else ever have white on the prob there? Any idea if I should clean it of and if so with what?
