Anyone using mas985s drip feeder for chlorine successfully?
Bama Rambler
24,165
None whatever. It's working great. I've adjusted it a few times and it adjusts the flow smoothly. Night and day different than the quarter turn valves that I've tried.
I was really surprised that it will adjust as low as it does considering it's on the suction side of the pump. I think I could get it down to 1oz/hr if I tried a little. You really need a calibration chamber if you want to get it that low. It'd be easy to make one if you needed to.
I still haven't heard from the other valve but I suspect that it'll just show up one day without warning.
Rangeball
785
Thanks for the update. It renewed my enthusiasm :)
I'm in no hurry this late in the year, but if it shows, will gladly take it off your hands :)
Once you have it set to proper flow, would it be easy to mark to reset it when you have to?
Rangeball
785
Thanks, that would be great :)
I figured I would somehow mark it for repeatability, but as touchy as the valve I had was to set, it would have been tough.
Bama Rambler
24,165
I tried it the other day and while I'm not sure it is repeatable to the drop/min or anything close to that, it went back exactly where it was as best I could tell without holding a stopwatch on it.
