pH is fine for extra confidence on the drop test but you should get a good one that at least allows a two-point calibration. Also, storage and care of the pH meter is critical - they all need to be stored wet in a specific solution (saturated potassium chloride, typically) to keep the tips from drying out. With proper care and calibration, a good probe can last a few years. Cheap ones will die in a few months.
As for TDS, why?? Salinity is best measured using a K-1766 kit which is an exact chemical measure of chloride ion (Cl-) content. Using an electronic TDS probe measures everything that is conductive in the solution, not just sodium or chloride ions. Thus, you have to calibrate the probe to properly measure TDS AND then use a correction factor to determine salt level. The correction factor needed depends on the specifics of your pool water as there are lots of different ions in solution that are not typically found in drinking water (which is where electronic TDS probes get the most use). The K-1766 has a standard accuracy of +/-200ppm but that can be made more accurate by simply using a larger test volume of water. An electronic TDS probe is going to have a +/-400ppm accuracy, best case scenario.
pH - Yes
All other electronic probe - No
