Hi, new to the forum. I bought a house with an in-ground pool late last summer so I didn't have to do do much maintenance. Managed to keep it algae free despite not having any idea what I was doing. However, I was using way too much trichlor. pH kept dropping and I couldn't find a reason why despite talking to "experts." Then I found this forum and found out it was due to the trichlor. Thanks to everyone who posts here, you've been way more informative than any other source.
We have a toddler and part of our pool safety routine is to keep the autocover closed unless the pool is being used. We have an appropriate fence, but I want to use the autocover as a redundant safety measure. I work in an Emergency Dept, so I'm a little paranoid about drownings. I read on this forum that sunlight is needed to burn up CC.
1.) If we keep the cover closed for most of the day, will this affect FC/CC levels?
2.) If it's not exposed to sun, I anticipate a will need less liquid chlorine additions. True?
3.) I'm in the process of SLAMing now. Do I need to expose it to sunlight while SLAMing?
4.) Is there any other reason why I can't/shouldn't keep it covered when not in use?
Thanks in advance!
Thanks in advance!
