I’m closing my pool for the first time. From what I saw on the net, I should be pouring 1/2 gallon of RV anti-freeze into the skimmer line. I poured about a quarter gallon and it won’t go down any more. Is that normal. I did blow out all the water using an air compressor.
Also, main drain at the bottom was emptied using my compressor and was closed. Meaning the vertical part of the pipe is going to have air in them. But wouldn’t the pipe underneath the pool just fill with water? Does it not freeze because it’s below the frost line?
