- Apr 27, 2018
- 150
- Vinyl
- CircuPool Edge-25
Until this past weekend it's been horribly cold in the Chicago area, so we just now did our opening. The cover came off Saturday afternoon (unfortunately dumping a bunch of spiny seeds and algae into one end in the process) and we started filling. After taking a break overnight, the fill was complete at around 4pm Sunday. Since then I scraped the bottom with the rake/net to get rid of some of the larger detritus, ran the robot for 5 cycles, and only added the following:
3 gallons of 2-year-old 12.5% chlorine (one of which was added during the fill)
1.75 lb of Stabilizer (via sock method)
1.5 bags of salt
And the current state is below. Wind is 20-25mph, so the surface is anything but calm. But you can still plainly make out the wrinkles in the floor of our 10-year-old liner, and if you look closely in the lower right hand corner you can see what appears to be cloudiness, but is actually a pile of salt from the half-bag I added right before taking the photo, but have not yet spread around.
Current numbers just 22 hours after fill, with only the steps outlined above:
FC: 6.5
CC: 1.0
PH: 7.4
TA: 80
CH: 100
CYA: 70
Temp: 70F
Salt: 3200 (should be ~3500 after the last ~20 lbs of salt dissolves)
Ready to turn on the SWG (once FC falls a bit), crank up the heater and hop in! Another utterly painless TFP opening!
1.5 bags of salt
FC: 6.5
CC: 1.0
PH: 7.4
TA: 80
CH: 100
CYA: 70
Temp: 70F
