Hello all,
A few weeks ago, I posted on here and got some great advice regarding the current design of my above-ground pool filtering system. The original post is here:
Why is my filtering system built like this?
I went to take a look the system today to start making a material list, and I forgot about the "third pipe" he installed. I'm not 100% certain what it's for or if it's needed.
I posted some actual pictures of it this time, instead of a sketch. Both pictures are basically the same, just slightly different angles. Please look at the first picture, Piping1.
The pipe all the way to the right comes from the skimmer to the filter. The pipe in the middle is the return line from the filter back to the pool. Great. But notice that the feed line has a bypass pipe, and I have no idea what it's for. If you close the valve all the way to the right and open the one all the way to the left, you can get water to come out of the bottom of the pipe that is in the background, under the deck near the pool. I guess it would sort of make sense if it was in the return line, a way to drain the pool or something. I assume I can redesign the new piping system without this bypass?
