Another new pool owner in VA!
ICKIER
4
Virginia
Well, this is my second season but I still consider myself new as I'm learning still...
Coleman Steel 22' above ground vinyl side above ground pool
A "starter" of sorts. Wife really didn't want a pool but gave in, telling me I was the ONLY one that was going to take care of it!.
I'd say I did pretty well the first summer. I managed to keep it clear all season.
I did NOT close it. The cover was too hard to maintain ON so the last time it blew off, that was it.
I skimmed and keep debris from settling all winter. Stayed rather clear. Early spring, it started to turn green. I knocked that out quickly.
My BIGGEST struggle was dealing with the pollen. I was turned on to scum sponges and 24 of them in the pool, squeezing them out daily for 2 weeks did the trick but surely there's something better out there! What a pain this was...
Then...the pool store was afraid I got it in chlorine lock. Somehow I came out of it w/ a few shocks and am back to clear and good levels.
Pain in the butt to vacuum as the water hose fed vacuum's bag is to low a mesh fine particles just bleed through.
I purchased an underwater hand vacuum w/ 500 mesh filter. Seems to trap the fine particles just fine.
Just purchased a solar cover. To y surprise it worked! 79 degrees until the cover. 83 degrees today!
Well, that's me and my pool.
I just made a post to inquire about my pump's GFI plug. Hoping anybody can help...
Message is here:
Welcome to TFP.
Please read
Pool Care Basics
Also, purchase a recommended test kit
Test Kits Compared
One of the cornerstone foundations of pool ownership is to test your own pool water and understand the basic chemistry of maintaining a sanitized and clear pool.
when you get a chance, consider adding the description of your setup to your Signature, which will aid the experts to quickly tailor responses to your pool and equipment, and you won't need to repeat it in future posts.
