This is new to me. We've owned a pool for 15 years and we've always had good luck. Almost 5 weeks ago, we lost at least a foot of water out of the pool (hose blew off the heater). Fixed the hose, put new water in - we have well water. Husband added metal out like he normally does and continued normal pool maint, it wasn't cloudy then once the metal was removed.
About a week later it turned totally green - we shocked the heck out of it and used algaecide and got it so it wasn't green, then went on a two week vacation and had our neighbor just keep the chlorine levels high. We've been back almost two weeks and have done what we know how to do with it but it's still not clear. It's no longer green but it is still cloudy. I'm not sure what to do next. Based on this site (which I just found) our CYA is too high to SLAM it. Our Combined Chlorine is .01 and pool is cloudy, not green. Phosphates are through the roof though (numbers all below). Should I lower water levels, add fresh water then SLAM it or should I use phosphate remover? The pool store wants us to raise the alkalinity and lower the chlorine level and remove the phosphates, which is almost in direct contradiction from what this site says. We ordered SeaKlear commercial strength phosphate remover and it delivered today.
Basics about the pool - above ground, 27' round. Estimated water volume is just under 20,000 gallons. We have a sand filter and currently use chlorine tablets to sanitize and before all this craziness would shock it a few times a summer. Always had a clear pool or could get it clear easily. Took the water yesterday to the pool store for testing. Photos of pool and test below, please help us get this fixed. We have a large graduation party in just under 3 weeks and we need the pool functional.
Free Chlorine: 5.62ppm
Total Chlorine: 5.63ppm
Combined Chlorine: .01ppm
pH: 7.2
Hardness 250ppm
Alkalinity (w/stabilizer correction) 85ppm
Cyanuric Acid: 89ppm
Copper 0.1ppm
Iron 0.1ppm
Phosphate 3035ppb
pH: 7.2
Hardness 250ppm
Copper 0.1ppm
Iron 0.1ppm
Phosphate 3035ppb
