- Jul 4, 2020
- 515
- Vinyl
- Pentair Intellichlor IC-40
Welp. Here we are again. First week of May, and I'm back in a SLAM because the pool started losing chlorine slowly after heating it. Every. Single. Year. For 3 years. It's fine when opening, I start to heat it, and I end up in a 15-day SLAM, using 40 gallons of chlorine, requiring tons of work, and making me fantasize about filling this stupid hole with sand instead of water. Once the SLAM is through, the SWCG holds chlorine at a low setting with no problem at all for the rest of the year.
I watch my chemistry really closely, try to keep things balanced, etc. Would anyone be willing to have a look back at my logs to see if they can see anything that would help? We have a very simple pool - no rocks, no water features - just a rectangle hole in the ground. I brush during opening though I seldom find anything other than a little black gunk in the skimmers from over winter stale rainwater getting in, which I clean up with chlorine. I pull the cartridges out of the filter and make sure they are stored dry all winter. Is it possible that the RV antifreeze is causing me issues? I use about a half gallon per line. I run the skimmer lines to waste when opening, so I don't put that in the pool, but the returns (3) all empty into the pool water when I pull the plugs and fire everything up. What am I missing here? If this is what I'm in for every year, it's just not worth it. Sorry for the bad attitude - I've had it with this thing. Any suggestions or questions are welcome. I'd love to be as excited to have the pool as I was the first two years.
Thanks!
Wes
Thanks!
Wes
