So I've been looking at replacing my pool pump for a more efficient model because I assume the one I have is old. I took a look at the label on the pump to figure out my horsepower replacement needs and my current electric usage. If I reading it correctly then it's a 3/4 horsepower. Less than one hp. That seems wild to me considering it's a pool that's approximately 28000 gallons. It's also strange that it lists the voltage has 230 / 115 and amperage as 6/12. I assume that means that since I have it connected to 240 it's running on 230 volts and 12 amps, but is it running on 6 amps? Attaching a picture. Can anyone confirm I'm reading this correctly at .75 hp and 230 volts 12 amps?
