My return path is shown in the diagram below. After the SWG, the water is split in 2 branches: one that goes to the valve that gets actuated through the automation system (EasyTouch) when switching between pool & spa modes, and another one that bypasses that valve and allows for a continuous flow to the spa, no matter what mode the system is in.
There is a manual valve that can control how much flow should go through this alternate path, and it currently is "full open".
I'm trying to understand the reason for this design:
- What is the purpose of always allowing some water flowing towards the spa? Is it to ensure a minimum amount of turnover even when the spa isn't being used?
- What should the manual valve (number 1) be set to? Are there times when I would want that valve to be completely closed?
- Why do we need 2 check valves in those specific locations? In particular, a pool guy who came to the house disabled the check valve number 2 by rotating it 90 degrees, claiming it had no purpose. For more context, these 2 valves are at the same height, and higher than the pool/spa water levels. I'm not sure what would cause water to come back up requiring the valves to prevent back flow.
Thank you in advance for your enlightenment!
