Hi, Jody here. I have a 16x32 inground 13,500 gallon pool put in the fall of 2017. Like a fool I let the installer talk me into the expensive Baqucil w/CDX system. 1st season went great and had no issues. 2nd year I started developing pink slime just like all the threads said I would so I've decided to go with the Salt Water generator and a Frog Cycler. I made my decision to go this route based on feedback from my sister who has this same type of SWG setup and she has been very happy with it.
I've purchased an CircuPool RJ30+ chlorine generator and a Frog 5400 series system. I also bought a TF-100 test kit for water testing. I haven't installed any these items yet. I did some research and it sounded like a good idea to me to do the conversion in the spring when I open the pool back up. That way the pool has had time to lose as much of the Baqucil products as possible.
I need your guys help. I want to start getting my plan together and to make sure I have everything I need to make this conversion go as smooth as possible. I plan on taking a weeks vacation and dedicate that solely too doing this conversion. I'm a very mechanical person and do all my own home repairs and upgrades myself. I'm confident in electrical wiring and have no fears of taking on this project but I want to go into this with a solid plan. I've been reading and researching for a couple of months off and on and figured I'd just start this task off using the expert opinions of you folks. Very impressed with the level of knowledge on this forum! Kudo's to all of you!
Initial questions:
- I've read about percarbonate being used as the initial step for the conversion. Should I attempt that? If so what do I need to get in preparation for it.
- I was thinking I'd get the baqacil to chlorine conversion done before I add the new SWG equipment. One less variable to deal with during the conversion process if I hold off until the water is converted and stabilities
