Been using TFP test kit for several years. No complaints. Been buying calcium, and stabilizer in bulk, on-line for use when needed. Buy muriatic acid from local family pool store, when needed. Use Pool Math to determine how much of what is needed. The past 6 months, or so, weekly readings have indicated a need, in varying amounts, for both muriatic acid and stabilizer. CH readings have held steady at around 400, and pH readings have been steady between 7.2 and 8.2. TA readings have also held steady between 60 and 80. Given the need to add some measure of stabilizer and muriatic acid on a weekly basis, are there are other things I need to pay attention to? Am I missing something? Thanks very much.
