It is hard for me to get close enough to the return in the deep end to add muriatic acid slowly in front of the return jet as recommended on this site. Since I can't slowly add it in front of the return like recommended on here, what is the safest alternative way to add it? If I bought a new gallon plastic pitcher, could I pour the correct amount in the pitcher and pour it around the perimeter of the deep end, on the same side as the deep end return and then brush afterwards, like I do when I apply bleach? If I use that method, should I add water to the pitcher first so it is diluted some when I pour it in? Or would it be safer if I just poured the correct amount from the pitcher or straight from the jug in several places around the deep end and then brush/stir up the water afterwards? I've got asthma, so I use the Klean Strip Green Muriatic acid which is 20% MA and has less fumes but I still need to be careful when using it.
