- Aug 23, 2021
- 153
- Vinyl
- CircuPool RJ-60 Plus
Todays test results are looking pretty good.
FC: 4
PH: 7.7
TA: 110
CH: 118 (leslies measurement 2 days ago)
CYA: 45
Temp: 74
I've finally got the CYA where I need it to be using 3" tabs so I've removed those from the erosion feeder, will use 12% bleach from here on out. My PH seems to be really stable, should I leave that TA alone or keep working on brining it down? Pool (and water) are now about 2mo old. Vinyl lined hard sided above ground.
FC: 4
PH: 7.7
TA: 110
CYA: 45
Temp: 74
