All pool plaster finishes should last 20 years or more. However, some last only 5 to 7 years, and some less than a year before the plaster surface deteriorates, discolors, and looks terrible.
Why the difference? Very often, plaster quality. As we have pointed out previously, studies on pool plaster and cement/concrete flatwork have shown that poor workmanship practices have the greatest effect on durability, deterioration and discolorations. Various studies also confirm that water chemistry plays only a minor role.
Fortunately, there are a lot of quality plasterers that understand the importance of proper plastering, and generally take an extra hour or two to properly plaster pools with good materials and good workmanship practices. Their pools usually last 20+ years.
However, there are some poor-quality plasterers that are in a hurry and use inferior and “short-cut” practices and/or materials to plaster quickly. Doing so allows them to underbid the quality plastering companies. Their pools usually last less than 5 years, and sometimes less than a year before the plaster problems begin. And when the plaster finish starts looking bad, they simply blame the water chemistry instead of their own sloppy workmanship. Sadly, they are enabled to do that by the NPC and APSP.
A “Pretend” Plastering Standard
A few years ago, the NPC and APSP got together to write an ANSI plaster standard. Unfortunately, they refused to mention and include important and critical workmanship requirements (well known by the cement and concrete industry) that would produce quality, durable, and discoloration-free plaster/cement finishes. No limits or standards at all!
Furthermore, the APSP/NPC standard doesn’t mention the defects, deteriorations, or discolorations that can result due to improper and inferior workmanship. That means there is no accountability for plasterers that do poor work. Sounds like a “protection” standard. Pool builders and State Contractor License Boards have little recourse to help pool owners.
What about Water Chemistry Standards?
On the other hand, APSP and NPC have very strict and narrow standards for pool water maintenance. Beyond that, their literature (incorrectly) suggests that if pool water is not maintained within their suggested water parameters, that plaster problems will result. No, in reality plaster studies show that slightly aggressive LSI (or CSI) water does not cause the defects or discolorations at issue.
The NPC and APSP should not be exaggerating and misusing the importance of proper water balance which leads to service techs and pool owners being incorrectly blamed for many different plaster problems.
Obviously, poor water chemical maintenance can result in uniform etching and/or scaling. Even some types of metal staining can be traced to chemical mismanagement. However, when plasterers attempt to associate spotting, streaking, mottling, discoloration of the paste, calcium nodules, spalling, etc. to water chemistry causes, you know there is no basis for that. They are factually known to be caused by improper materials, application or curing failures.
The Bottom Line
APSP and NPC should rewrite the ANSI Plaster standard and adopt applicable workmanship standards (similar to ACI and PCA standards) to promote durable and discoloration-free plaster finishes for pool owners. That would serve the industry much better and help prevent plaster problems occurring in the first place.
However, this ongoing travesty probably won’t change until the entire pool industry becomes informed of these issues, rejects the false claims that water balance is what causes the above plaster problems, and demands that the NPC and APSP make things right.
My father, who was in the plastering business 45 years ago, provided quality and discoloration-free pool plaster to their customers that lasted 20+ years.
Addendum:
When a plaster finish develops discoloration or defects, the following questions could be asked.
What does adding too much water, or too much calcium chloride (hardening accelerator), or performing too much water troweling, or overly late and excessive hard troweling do to plaster finishes?
And wouldn’t “tenting” pools (to overcome harsh weather conditions) and taking an extra hour help to produce a higher-quality plaster finish?
Those are important issues that are missing from the APSP/NPC/ANSI Plaster Standard.
The following links provide additional details regarding these issues.
A Plastering 'Watch List' | Professional Watershaping | Watershapes
Kim – Ten Steps to Durable and Discoloration-Free Plaster – Pool Help
The Bottom Line
Addendum:
