- Aug 4, 2021
- 10
- Vinyl
- Intex Krystal Clear
I'm about 4 days into a new 3,600 ga vinyl above ground pool.
I am waiting on the Taylor water testing kit to come as I didn't find out about this forum until later. In the meantime I am using a few water testing kits I could get my hands on.. the HDX kit and one from HTH.
I also have strips from aquachek because I was curious just how wacky out they would be according to everyone's comments about them.
My CYA is at 60
My Alkalinity is at 250
My PH is 7.6
My Chlorine is at 5
The test strips have the PH higher than the test kits do. But they too say Alkalinity is high.
I have the Intex ECO20110-2 sand filter SWG system
I also have muriatic acid and a jet I can swivel up due to a modification of adding a hayward skimmer and return.
I believe that it's suggested that I add muriatic acid to lower Alkalinity then aerate to raise PH correct? Add then retest after 30 min to see if more is required?
My CYA is at 60
My PH is 7.6
My Chlorine is at 5
