Algaecide help please!!
For the FC and CC test, use 10mL sample and each drop is .5 FC. Will save reagent.
Forget R-0006.
Post a picture of the pH test in the comparator and your assessment of pH level.
If the sample turns red, pink, or yellow, you are done, your TA is zero, and your PH is very very low (4.5 or lower).
Use Soda Ash aka Washing Soda. Calculate how much to use using Poolmath. Set pH of 6.8 now and 7.5 as target. Enter 0 for TA. Add amount it states and circulate 30 minutes. Test pH, repeat until your pH is in the 7's, then test TA,.
Ok so I put in all the numbers. It has its recommendations up. I’m not sure how to share it to post
I went by what the pool calculator said to get. Just waiting on the calcium chloride. I had to order it online. Is supposed to be in Monday. Do I go ahead and administer the other things still or wait til Monday?
Post a full set of results here. FC, CC, pH, TA, CH, CYA. Type them in the thread post.
Take a picture of your pH test, neutral light with a white background.
Press this button and post the picture.
Click pH on that screen. Set pH of 6.8 now and 7.5 as target. Select pH up/Soda Ash as the chemical type, Enter 0 for TA. It should give you an amount to add.
Add amount it states and circulate 30 minutes. (to prove you did it right, should be 3lbs.)
Test pH, repeat these 3lb additions, until your pH is in the 7's after 30 minutes, then test TA.
Get a 5 gallon pail, add hot water, dissolve, then pour in front of a return slowly. It may take several batches.
