Ok, I have a small 6000 gallon above ground pool. I have a swg and sand filter but my salt cells died so it turned green. With spring coming I’ve ordered new cells and need to kill the algae.
so my cya is low, at 20 but I don’t want to raise it while slamming thinking it’s cold and not too sunny here so I don’t need a high cya since chlorine level would drop slower. So leaving it at 20 let’s me have a lower fc level?
my ph is 7.4
heres the thing, my fc has been at 10 for days. It doesn’t drop even over 24 hrs yet the algae isn’t dying? Or at least I don’t think it is. Typically when algae dies it sinks and you vacuum it up, right? My water is green, no sinking algae and zero improvement in the water. Water temperature is cold so I’d expect the fc to not drop very quickly but with all the algae I’d expect it to at least drop until it’s clear. Or at least get water improvement. I’ve backwashed and the filter is definitely filtering out a ton of algae so I would think is working properly, my pressure is fine. So why isn’t it dying off?
my ph is 7.4
