Thanks, we've been running the robot for 2-6 hours a day but we haven't done any serious brushing until we know we can get the FC levels up. I'm getting a bit hype to do some real work and get starting on the TFP maintenance.Brush or vacuum, doesn't matter the order but brushing twice a day is what will make the slam work among others but vacuuming need not be unless there lots of debris. I like to let my robotic cleaner run around while slam is happening.
Brush as soon as you can. It's an important part of the processbut we haven't done any serious brushing until we know we can get the FC levels up
I've done it twice today and my FIL has been doing it daily since I posted. I'll keep brushing as part of my diving fun.Brush as soon as you can. It's an important part of the process
My OCLT is going to be for fun as I don't expect to pass it this quickly. Now that we have the test kit my plan is to add a little chlorine every hour or two and to scrub it 3-4 times today.During the SLAM Process just stick with testing fc.
For a successful SLAM Process
you need to continue to MAINTAIN Slam level fc for your cya as often as possible (multiple times per day is best) until you meet ALL 3 end of slam criteria-
You are done when:
CC is 0.5 or lower;
You pass an Overnight Chlorine Loss Test
AND
The water is clear.
(Crystal Clear w/no algae dead or alive)
*Check & scrub every nook & cranny where algae may hide (light niches, steps, drain covers, ladder handrails, skimmer throats/weirs, abandoned lines, autofill, overflow drains, etc.)
*If water can go there, algae can thrive there.
*Run slam level water through all water features & lines for at least a couple hours a day during the SLAM Process.
*Brush & or vac daily (this breaks up biofilms that algae uses to protect itself from chlorine)
*Backwash/clean filter when pressure rises 25%over clean pressure.
Finished scrubbing every inch again.During the SLAM Process just stick with testing fc.
You are done when:
CC is 0.5 or lower;
AND
The water is clear.
Sunset is 8:45 right now and sunrise is 5 am. It doesn't get "dark" until 11 or so.
YesI've done it twice today and my FIL has been doing it daily since I posted. I'll keep brushing as part of my diving fun.
Don’t count yourself out - but don’t rush it.Finished scrubbing every inch again.
Cc is zero.
Water looks crystal clear.
I'll play with an oclt, expecting to fail, but I think we're getting close.
I like to aim for 30 minutes after sunset & 30 minutes before sunrise just like when huntingFor the oclt, do I wait until after sunset or it's dark?
Is the 5-6 hours enough time lapse to get a good reading?
Nope. It's safe for all pools, equipment and even swimmers. It's less harsh than tap water.Will slamming a liner pool cause any issues?
