Gonna be kind of long one, but here goes. Around two weeks ago, I thought for sure I was dealing with pollen in the pool. Water was still pretty clear but the bottom of the pool was dirty/greenish yellow. I was able to get almost completely cleaned up with the combo of filter socks and adding some DE to the sand filter (the filter sock will would be full of green/yellow at the end of each day). Then came a couple of days of the motherloads of rain. Boom, I have a swamp.
Steps I have taken since:
removed plastic drop in steps and metal ladder
running robot as much as possible
brushing pool multiple times daily/vac when can
filter sock/DE
SLAM process
I have been doing this for over a week now. I have passed to overnight chlorine test for multiple days in a row. My pool is still cloudy/dull/green (pics should be attached) and every morning the bottom is still completely covered in something when I brush it. I have continued to SLAM since my pool isn't clear and also did a deep clean on my sand filter.
This morning as I was brushing and testing, my robot went up and covered my skimmer and unprimed my filter pump. When the pump came back to life, I was standing over the return in my shallow end. It appeared that what ever I have been brushing off the bottom of the pool came shooting out of the return.
Is my pool not clearing up because it's not filtering well enough? Do I continue to SLAM? Just looking for some guidance here. Here are my current numbers:
FC-22
CC-.5
CYA-45-50
TA-90
PH-7.8
Any help is appreciated and happy to provide any additional info. Thanks in advance!
filter sock/DE
SLAM process
FC-22
CC-.5
CYA-45-50
TA-90
PH-7.8
