Greetings,
Looking to get rid of recurrent algae. It looks like mustard algae. Pool water is crystal clear, but keep getting algae on the walls and floors.
I've been through repeated shocks and super shocks with algaecides (Yellow ut, Green-to-Clean, & oxyethelene ethelene dichloride), throwing all equipment in the pool, scrubbing walls and floors and the algae returns 3 to 5 days later. This has been going on for the last 6 months.
I believe the cause is high CYA. It is over 100. There doesn't seem to be a reliable test for levels that high. Best guess is that it is around 150 ppm. I'd remove/replace water, but there is a problem there. We have well water and well issues.
We looked into having fresh water brought in, but the volume of water we would need would cost us about $1500, maybe more to get CYA levels at half the current value. Not a great option. The CYA levels are due to using tablets—our fault. We are using liquid chlorine now.
We have been considering augmenting the chlorine with UV-C (i.e., Delta E-46) as a way to mitigate some of the disinfectant load and slowly, over time, drain off water and refill with the well (once the well gets fixed). It takes hours to fill an inch or two in the pool and it taxes both the well and the pump.
Appreciate any thoughts or observations.
• Pool is a vinyl-lined in-ground pool, 20,000 gallons, screened-in
• Filter is a Pentair Quad DE
• Pump is Pentair Intelliflow
• Flow rate is set at 45 GPM
• Pump on-time is 11 hours per day
• Bathing load, very low
