I am 19 days post slam. My FC target is 7-9..Min of 5...The lowest I have been to is 6.0. I noticed yesterday 3 spots about 2" long at the bottom glass block window line inside my spa that were greenish. I drained spa as I was planning to clean around light and lower spa inlets. I scrubbed areas with brush and hit with a spray of chlorine. I removed floating debris (very small) after with pool net. I cleaned lower portion of spa walls with 33% MA wash as I think I have minimum scaling. I filtered remaining spa water returning to spa only, then refilled spa and filtered spa only water for about an hour. I added chlorine last night to raise to 10 and did & passed OCLT this AM. Pool is still amazingly clear. After pump started today, I noticed a cluster of "stuff" around the main drain..looked puffy...I switched to pool vac and used Pole on vac to suck up the debris. This is the ONLY debris I have seen in the pool in 19 days!
Sooo...I'm believing algae in spa started due to minimal circulation in there as I have been returning water to split spa/pool.
Since I did have algae, but my FC has never been at or below minimum since I completed SLAM, can I assume that since I passed OCLT and have maintained FC at target levels that this was just a result of the 3 spots in the spa and my proper FC level killed it and I most likely will not have an issue moving forward? I have never had any CC since SLAM was completed 5/28.
Even though FC is in target range, algae can still grow if areas of low circulation? This seems obvious since I in fact found it. I just was not expecting to find it since my FC level has been maintained. I do check it daily..most days morning and night as I am still learning my pool.
My most current full test.
FC 10
CC 0
PH 7.5
TA 60
CH 260
CYA 50
CSI -.32
I appreciate your guidance!
Ed
FC 10
CC 0
PH 7.5
TA 60
CH 260
CYA 50
CSI -.32
Ed
