- Aug 5, 2015
- 122
- Plaster
- Pentair Intellichlor IC-60
We opened last weekend and recently discovered our 1 yr old SWG & automation package is a lemon and wasn't actually producing chlorine the entire time. Add to that our pool openers "balanced the water" at opening by only addressing salt, FC & pH. I've since discovered there is basically no CYA in our water (at 20 I could still faintly make out the black dot). I just added 4 lbs stabilizer to start and was going to retest. Should I add more to start? Keep in mind while we have a salt pool (current level 3100), the SWG is not working so we're manual until that issue gets worked out. I want to SLAM tonight but am not sure what levels I should be aiming for or what charts to follow.
Current CYA is 20 so aim for SLAM level 10?
Target CYA with already-dosed stab. 40 so SLAM 16?
Eventual target CYA level 60 so SLAM 24?
I'm not sure, but I kind of think we've got yellow algae. I first noticed what looked like pollen on the pool steps, but we also are having a reallly bad pollen run over the last few weeks (my daughter & husband are dying). THe wheels on our robot are green but with a yellow tint. I've read yellow is harder to treat, so again I'm not sure what levels to aim for. Help!!
