Hello All,
Have been doing lots of research and reading. I updated my signature so hoping everything shows up. We set the pool up 1 week ago, 1st time pool owners. Pool chems and supplies just arrived Friday
We have cloudy water, I am suspecting from reading it is algae. I am guessing it’s due to lack of chlorine and CYA?? Would like to get further educated
Tests taken today, Monday with Taylor K2006C
FC - 1.6ppm
TC - Unable to test with current kit
CC - .2ppm
Ph - 7.8
TA - 240ppm
CH - 210ppm
CYA - 0
We are running currently using 3” Trichloro pucks in a floater. Sounds like we should be using liquid chlorine.
We have shocked the pool 2 times, 1lbs each time Friday and Saturday the pump has ran for 24 hours each of those days.
All day Sunday the pool was visibly clear, but today it went cloudy again.
I have performed a backwash and rinse on the sand filter.
Pool has been cleaned daily, but only surface to mid level cleaning. No vacuum at the moment, but will be coming.
We are in a wide open space, no leaves etc. just grass clippings.
FC - 1.6ppm
CC - .2ppm
Ph - 7.8
TA - 240ppm
CH - 210ppm
CYA - 0
