Hi all,
I'm a few months into pool ownership of about a 4 yr old in-ground pool (details in signature). Prior owner had the variable speed pump running 3200 RPMs, not sure why. After replacing the very worn/dirty filter cartridges and reading about pump setting recommendations on this site, I adjusted the pump to 2000 RPMs, as it seemed like the energy/flow sweetspot. The clean filters dropped my filter pressure from 25 to 12. The RPM change dropped it further to about 8. But, after changing the speed, I noticed the pump lid has an airspace (see photo with pump running). The flow looks fine and water is fully over the pump inlet and up to the edge of the clear lid, but it's not full. Increasing the pump speed shrinks the air space, but doesn't eliminate it.
Reading more here led me to worry it meant a suction side leak, but I have no bubbling in the pool from return jets, no visible leaks when the system is on or off, and filter pressure and water level in the pump basket hold fairly constant on or off. Nonetheless, I replaced o-rings in all the suction side valves, replaced the pump lid o-ring, and even the lid itself. Didn't change a thing. I've also shaving cream tested everything on the suction side and can find no signs of a leak.
Is this normal and I'm worrying about nothing? Does an efficient pump speed on a low pressure, clean system just look like this? I don't want to ignore a problem, but besides the visual appearance of the lid everything seems to be working great. Any advice appreciated!
