Air Relief Valve
LisaDLu
172
Palm Desert, CA
There is some leaking coming out of the round housing that sits below the gauge on my air pressure relief valve. I found what looks to be the same part on Leslies called a High Flow manual air relief valve. Is this part easy to replace? And do you think this is where the problem is? We have replaced just the gauge before but not the whole housing. Thanks in advance!
If you can screw in a light bulb you can probably replace this. :) Be sure to seal the threads with teflon tape and don't use too much pressure screwing it on - you do not want to crack the filter housing! You should not need gorilla-strength to remove it or replace it.
Look online (amazon) for the part as well for price comparisons. Use your filter make and model to insure you are getting the right part.
Reactions: LisaDLu
