Air pressure, my new cartridge filter, and winterizing
sande005
957
White Bear Lake, MN
CircuPool RJ-45
Thinking ahead to winter closing. Being in Minn., freeze protection of the pipes is important.
With my old sand filter and multiport, I could hook a compressor up to the lower pump drain hole, set to "recirc", and pressurize the whole system. Thereby blowing out the skimmers, jets, and main drain. I used to set the compressor to 60-80 lbs at the compressor, assuming that as the air left the 1/2" hose, there was a big pressure drop as it expanded into the rest of the 1 1/2" or 2" plumbing. And quickly dropping further as it blew the water out of whichever line was currently open. It's a smallish 8 gal tank compressor, so not a lot of air volume available. May have to do each line a couple of times individually to push most of the water out. And then I pour in a couple gallons of antifreeze in each line. The main drain took the most pressure and time before I would turn the valve and air lock it.
Now with the new filter, there is no "recirc" setting. Either the filter is "on line" or I can use the new 2 way valve to pump to waste. The filter manual has warnings about air compressed in the filter causing (explosive) failure of the housing.
I would take out the carts, and fully drain the filter first. But would I be at risk of damaging it (or me, with shrapnel)? Are there alternatives to getting the water out of the plumbing?
Not sure having air pressure in the filter housing would be an issue, but that may not even be necessary as you appear to have other options. For the suction side, you have the option of pushing air backwards from either the 2-way valve or the pump inlet itself. On the pressure side, you could push air after removing the SWG cell.
Thanks for the suggestion. Hmmm, will have to explore the options for plumbing parts at the big box store. Need to build an adaptor to reduce the 2" waste side of my new valve to allow a 1 1/2" flexible hose to be added for lowering the water level. Perhaps a second that allows the compressor to back feed air.......
I like the idea of going from the SWG side...just need to make sure I can find something that will adapt to the existing unions....
Reactions: Texas Splash
