- Jun 17, 2024
- 42
- Plaster
- Pentair iChlor 30
If have rooftop solar, and in-floor cleaning. When the rooftop solar is active, every time the distributor ("5-port actual valve") rotates to a new set of heads there is air in the return from the solar, it blows out from a jet for bit, then no more air. Until the distributor rotates to the next set of heads.
Also, when rooftop solar is active the pressure at the distributor drops from about 14 psi to 2.5 psi. The pressure at the sand filter remains at about 14.
In the first pic you can see the check valve (with window) on the rooftop solar return, just left of the gas heater. Every two minutes, as the distributor moves to a new set, this window fills with a flurry of bubbles for about 10 seconds.
