Trying to figure out why I am having air bubble issues band it is driving me crazy for the last month any help would be appreciated
Water is flowing through the system well water level is good
Filter pressure is 10 PSI
Water chemistry is good per local pool store
having persistent algae issues on sides and bottom
Water is clear
Releasing a lot of air from the filter when i open the air relief valve
Pool not leaking water
Air bubbles at top of pump basket
Replaced pump motor and seals mid may
Replaced the pool pump strainer lid and o ring and lubricated.
Check unions and o rings they were ok
No visible leaks in plumbing other than a small drip leak in a screwed connection after the pump into the multiport valve
Checked drain and tightened drain plugs in pump
No impeller blockages
Water is clear
