- Feb 6, 2018
- 188
- Vinyl
- Hayward Aqua Rite (T-15)
[FONT="][/FONT]Hi, For my 25k in-ground pool, I have a SP3210X152 TriStar 1.5 HP Pool Pump (Max Rate, Two Speed) which normally ran fine at 10psi in high speed with a clean filter.
After having a solar system installed, the pump now runs fine at 13.5psi high speed with the diverter valve bypassing the solar cells (3.5 extra psi due to the check valve, additional elbows and diverter valve I assume?). When flow is directed TO the solar panels (2 story roof), pressure increases to 26psi in high speed (company says expect a 2-15psi increase which I'm within).
The problem is with 26 psi going to the roof, a 1" air gap in the filter basket develops. Air doesn't seem to be getting in the pump suction, but I was told the filter basket should always be full in High Speed. This never happened at 10psi and doesn't happen at 13.5psi (flow bypassing the solar panels) - the air gap only shows up when pumping up to the solar panels.
The installers said since it is on the inlet of the pump, it has to be an air leak. My pump filter cover is on tight, O-ring is clean, cartridge filter is clean, and all 7 solar panels are rated for a total max flow rate of 77 gpm. Plus its strange that the air gap would only show up at the high pressure.
Would you have any idea why the air gap ONLY shows up at 26psi? Thanks!
-Mark
-Mark
