Hi all -
Was working on the pool this weekend and one of the things I did was pull my IC-40 and acid wash it. It wasn't bad but had quite a bit of pollen that made it past the filter in there. It cleaned up well and after I put it all back together I had a small drip on the pool side of the SWCG at the union. I pulled it off again, pulled, cleaned and lubed the o-rings and I think I've got the leak stopped. All that said, I now notice a steady stream of bubbles from one of my returns. I wouldn't think a small leak on the pressure side would cause air but other than that I don't notice anything wrong. Pool is full to half way up the skimmer (not sucking air), filter baskets are clean and only a tiny little bubble hanging out at the top of the pump basket. Any clue what to start looking at? Here's a pic of my pump setup and one of the leak (zoom in on the palm tree reflection and you can see the bubbles):
