I'm all of sudden having a bunch of air bubbles in my pool when I turn the pumps on. I think it is b/c this seal thing (don't know what this is called) is loose (see video -> leaking seal). I couldn't even tell it was loose, because it is dry when the pump is running, BUT, when I turn off the motor, little streams of water shoot out (you can see it in the video), which indicates that this isn't airtight. The thing is screwed down super tight, so I don't think I can make it even tighter. How can I fix this?
EDIT 1: I've added a screenshot of the moment the water shoots out in case the video doesn't work that well. The water are those thin lines shooting out around the 10:00 and 1:00 positions (assuming that 12 is the top middle of the image)
EDIT 2: Thanks mknauss! Here's a youtube link 2017 10 28 13 26 13 - YouTube . Here's another video also showing how air seems to be going in, and stopping when I use my finger as a seal (2017 10 28 13 56 35 - YouTube).
Thanks!
Thanks!
