I just attempted to winterize and close my pool for the first time without paying the pool company $400.
I think, as is probably normal, I am really worried that I did it correctly. I live in Central Illinois--and last winter we had record cold of -30 degrees for a few days.
I have two return lines by the stair, two return lines in the deep end. I have two skimmers and one main drain.
I have an automatic pool cover that keeps water out.
I drained the water to a couple of inches below the skimmers.
I used a pancake air compressor to blow air using both my pump drain and the sand filter drain. Using the air compressor hooked up to the pump and sand filter drain and a combination of the valves on my filter and plumbing I am assuming I was able to most of the water out of the pipes.
I used a combination of the compressor and a shop-vack as suction from the skimmer baskets.
I ended up using RV anti-freeze only in the skimmers lines as it was easy for me to pour it in those lines.
I was not able to get anti-freeze into the return lines as they were pressure locked.
On top of any normal worries I have as a result of this process, while blowing out one of the return lines--I noticed a bit of bubbles coming out after the return was capped. I removed the cap and re-applied the plumbers tape around the threading and then capped the return line. However, a small(er) amount of air bubble continued coming through. Once I turned off the air compressor, the bubbles ceased.
How much of a concern is this? I couldn't tell what the cause of the bubbles was--could it be the housing I am screwing the cap into? The cap itself? I don't know if anyone can give me a proper answer--but maybe just some guidance could help?
Thanks!
Thanks!
