tcat
- May 30, 2012
- 1,787
- Plaster
- CircuPool Edge-40
I have no riser. But yes, seems all 4 wheels don't touch, just lays on the flat pebble surface (about 1/2" high). I was thinking if the rear wheels were slightly larger so they touch. I've seen some people use skimmer baskets upside down with a weight strapped to them. Replacing the drain covers with a taller one might work (other than pita removing them). $15ea. for the drain clips might be easiest.Once I removed the risers on mine it does not seem to get stuck. I did notice that when it was getting stuck it was getting onto the drain ok but then high centering where all four wheels were not touching. With the solid pebble portion of my drain I beleive it was sucking itself down so it was unable to rock off. Maybe if you move your bumper mod all the way forward so it cannot traverse the drain in the first place?
