After changing sand in filter.... sand in pool....
Mikey311
81
Powder Springs, GA
As the title states, I just changed the sand in my 500lb Hayward sand filter. I watched a few "how to" videos and while the process wasnt fun, I felt like it was pretty straight forward so tackled it myself.
After startup i noticed sand in the pool from the returns. Yikes. It seemed to stop so I thought it might be normal for some sand to come out and tried to push it into a single spot in the pool to remove when it gets a little warmer.
Today, I noticed my pool was low on water (dealing with a spa leak I cant get a contractor out to fix) and the pump was struggling for water so i immediately starting adding more water to the pool. Its back to normal for now.... but notice MORE sand around the returns....UGH.
What Did i do wrong? Please help.
One thing I noticed with the lateral assembly is if I put it on the bottom of the filter.... it wouldnt reach the multi-port value.... so as it was installed previously, I had to add some sand... THEN put in the lateral assembly to get it to reach the multi port value.
Not sure if this is normal or not, but thought I would mention it. Wondering if it settled some???
Is it possible the laterals/pipe settled in the sand since I didn't add water before I placed it? So maybe I have a gap in the pipe and the multi port valve?
I guess the other option is the lateral got damaged but I did try to be careful in that regard.
It's very possible the laterals got pushed to a point they separated or cracked. Watch to see if anything changes after you do a thorough backwash and rinse to clean the new sand. If you still continue to get grainy stuff in the pool, you may have to opera it up and inspect. :brickwall:
Reactions: Mikey311
Thanks for the assistance, very much appreciated.
I checked the lateral pipe, didn't seem to settle.
I then backwashed for over a minute and then rinsed over a minute as well.... the water in the view piece (sorry not sure of the proper name) doesn't ever seem to clear up, see sand in it. It's there a chance this is normal in any way or pointing to a damaged lateral at this point?
Anything else I should try before replacing the laterals?
You should backwash until the water is pretty much clear in the sight glass then rinse until all the grains are gone & its really clear.
One thing I noticed with the lateral assembly is if I put it on the bottom of the filter.... it wouldn't reach the multi-port value.... so as it was installed previously, I had to add some sand... THEN put in the lateral assembly to get it to reach the multi port value.
It should fit perfectly.
Probably the wrong assembly.
I probably broke when you pushed the top on.
I would replace the assembly with the correct part.
  • Sad
Reactions: Mdragger88
Pile of sand I pushed to one spot to get out soon.... I had pool in recirculate for last day as I just did a vitamin c treatment for metal stains.
Was trying to figure out sand issue before returning it to filter mode and getting water balanced.
Chasing my tail with this pool....
