So we have an above ground pool 14ft round ultraframe thing. We got a used huge (7000 gallon) filter/sand/salt pump off craigslist about 4 years ago and it has been doing ok. It pumped well and once we cleaned the salt chlorinater cell last summer it seemed perfect after slamming and getting my levels all correct. It was working when summer ended and now it makes a humming noise but doesn't actually pump. I disconnected the pump (it goes into first) to see if any water would just flow from siphon and it does. So water is going through the pump but its no difference when it is off vs on. I can't get it to back wash or prime so I can get my pool opened up. I do have the crappy little thing that comes with these pools and we set that up and its going for now but I really want to get another sand and salt water system. The controller for the salt water system is attached to the pump or I might try to just replace the pump and they don't seem to sell a replacement part for this model number. I need advice on if I should try to get it fixed, replace a part or if I am better off just getting a whole new system and what yall would suggest.
I am in austin tx.
I am in austin tx.
