- Jun 7, 2017
- 46
- Plaster
- Pentair Intellichlor IC-60
Hi - I have a set of 17 year old equipment (single speed pump few years old); looking to go with Intellicenter or OmniLogic and could use some advice on making sure I get the right stuff. Pricing from pool companies is like 20k and I found the same hardware for around $8k so will DIY:
Equipment Config in Signature - pics attached as well
Assumptions
* Going to split the three-way valves for both suction and return; so I will have (Floor Drains, Skimmers, Wall Returns, Floor Returns) - total of (4) two-way Jandy Never-lube
* Adding Propane Heater - plus bypass valve/plumbing?
* Adding Automation
* Will stick within the same brand "Ecosystem" - Pentair or Hayward - for SWG, Pump, and Controller (and pH if I add)
* Pump size - presently I have Jandy 1.5hp single speed
Equipment
Automation Controller (Intellicenter or OmniLogic)
Propane Heater (RayPak 400k)
SWG (Pentair IC60 or Hayward AquaRite)
Pump (Pentar Intlelliflow or Hayward Ecostar/Tristar)
pH (Pentair IntellipH or Hayward Sense & Dispense)
Valves - Jandy Neverlube
Filter (Pentair FNS60 or Hayward/Starite Modular Media)
Lighting Transformer - for path lights etc
Questions
Any suggestions on Pentair vs Hayward? They both seem decently reviewed.
Pump Size - pool company recommended a 3hp Tristar and just run it lower RPM; but would it be better to go smaller and do same? I would never run 3hp anywhere near 80%+.
Any value in automating the Jandy valves for suction & returns?
I like idea of multiport valve but I know I don't need if I go cartridge. Generally for vacuum to waste and maybe recirc if filter is not working. Any suggestions for how to handle this?
Pool company told me not to have bypass on heater - but I would only run it in May, early June and September (on demand when I am going to use it). Does it make sense to have a bypass on heater so I am not running salt water through it all the time?
If I do bypass heater - do I need to drain it to avoid water sitting in heat exchanger/piping? Again I would likely not use in July/August/early-Sept at all.
I do a good job of keeping water balanced - so SWG will take the CHL out of my mind; mixed feelings on MA Dosing System but its reasonable cost around $500 I think and one less thing to deal with.
I have two main drains - is SVRS more headache than its worth?
Any other suggestions/ideas?
Sorry for long post - but been reading alot of just wanted to put it out in one post.
Thanks much - Jason
Assumptions
* Adding Automation
Equipment
Questions
Thanks much - Jason
