I have a 1.5HP pentair superflo VS pump. I'm looking to add more time options than the 3 that are built in. Not speed options, just times. I'd like to run it low most of the time with a few 1 hour periods on high. Two speeds, but several times of day.
This pump is relay based which is good I think. I'm thinking something simple like an Intermatic timer would work, but I don't know if they can switch 24VAC or 5V. They have about 1,000 different options. Also, I'm no electrician and would rather not hard-wire. I'm looking for simple, cheap, etc.
I'm looking for: "You plug this thing in to the wall, and run the 5 (or 24) VAC line into the thing, and from out of the thing you plug it into one of the relays on the pump. It energizes that line on the schedule I set. Done deal"
An electronic or manual "thing" is fine. I just don't what the options are.
Thanks!
Thanks!
